I'm thinking about getting a small dirtbike expansion chamber and welding it to the sbp header. Any thoughts? I have access to the tools and a local motorcycle wrecking yard has hundreds to choose from for about $20 each. Anything in particular I should look for, besides the correct shape and size to fit the bike? For example, if the new chamber's header is 2x the size of the sbp header pipe would that cause problems?
Also I'm picking up a dremel tomorrow and am going to open up the transfer ports and smooth out the intake and exhaust. Anything else I should do? I remember a while back looking at a different engine the transfer ports had these ridges in them just below the opening, should I remove them if theyre there on my engine?
