Today was a good day and a bad day, The hub adaptor and 48 tooth sprocket came from Manic Mechanic and also the 1 inch throttle assembly. I started with the Hub adaptor and sprocket, a lot of people say the stock 44 tooth sprocket works well on the 26" bikes but since mine was a 29er I bumped the sprocket size up to a 48 tooth, it was a pretty easy install other than getting the chain around the primary sprocket. That was kind of a pain, but it all worked out and it is all hooked up.
Then I started on the throttle assembly and MAN what a pain in the azz it was, the new mini bike throttle had different threads for the cable than the china girl, plus the screws were to short, then I just decided to drill out the stock throttle to 1 inch and ended up breaking it so I went back to the 1 inch throttle and took the stock cable and cut the threads off of it, then I used a brake handle adjuster and fit it into the throttle assemble to take out the cable housing slack. it works but I will still just buy a new correct throttle cable!
All I had left was the Clutch lever and I took the stock one and drilled it out to 1 inch but it needed to be spread apart just a little tiny bit.... Yeah ...so I use a screwdriver and pry it just a little and SNAP it breaks in two.... Crap! So now I have to find a 1 inch motorcycle brake or clutch lever to use. On a good note I installed a set of Leather Saddle Bags on the back rack after I shortened the cross strap so they would hang right, then I made a leather Gas tank topper, I tried to dye it as close as I could get it to the bags. It turned out nice, it's still drying so tomorrow I will secure it to the tank!
