silverbear
The Boy Who Never Grew Up
Pretty cool, you guys!
SB
SB
That looks awesome!
As I understand it, it has to be laser toner, not ink. I'm not sure how the toner forms a "resist" but it does.
Just don't use waxpaper for the iron-on, unless you want a messy blur......
How well does aluminum etch......it is nonferrous so I doubt it's possible using the electro technique. Maybe I will try the wax and pure muriatic acid for a badge for my blue Dyno.
Sooooo what if I used current and acid kinda like nickel-plating backwards.
And how would running the current through a transformer affect it?( i.e. high volts-low amps)
If I'm not mistaken, most photocopiers are actually laser printers these days, so making a copy of a design should work.
Hey Scotto-
You've heard of "Anodized Aluminum" right? Aluminum conducts electricity, it will electro etch just fine! If you don't have a transformer, muriatic acid will eat it away FAST so don't leave it in too long...
Anodization is great, then Tiodization came along and is a cool way to color titanium. How does one tiodize titanium......with oxides? A titanium head badge with color would be the shiz in my book.
I have lots of transformers, been charging lots of batteries and such for decadesLet's ride!
3. Using a laser printer, print the image on photograph inkjet paper. Yes it works. I jammed the machine with some heavier stuff but the lighter weight paper works. You need to use glossy inkjet paper or purpose specific etching paper (E3 Etch).
OK, I tried the laser printed design transfer...
I should have read this part more carefully. DO NOT use the thick "Photo Paper" to print your designs for transfer. You'll NEVER get the paper off after you've ironed the design to the metal.
Well, the brass head badge looked nice all shined up but the brass dulls fast and then gets that patina which I wouldn't like. I tried clear brass lacquer but I didn't like that either (do I sound like the princess and the pea?).
So, I pulled the transformer back out, cooked up some zinc electrolyte and plated the brass.
I like the color in the background but the paint would get all messed up when I was polishing the brass so, off I went to Harbor Freight and bought some black powder coat ($3.99). Mixed some up with acetone and painted it in the low background. Of course I got some on the high places so after the acetone evaporated off I used steel wool to get the powder coat off where I didn't want it.
After I cooked the powder coat in the oven I plated on another coat of zinc and buffed it out on my buffing wheel. Buffing wheel didn't mess the powder coat up at all and the zinc came out nice and shiny.
