silverbear
The Boy Who Never Grew Up
I notice that on an adult sized delta trike with a 26" wheel up front the rear wheels are often 24", but not always... sometimes they are also 26". I'm still in the planning/ gathering parts stage of a hybrid trike build using a 1963 Schwinn American Deluxe ladies bike to be converted to a trike using a lawn tractor differential axle. It will have a 2 stroke vintage Villiars engine powering the rear axle and up front an electric Golden Motor 36V pancake motor.
Top speed on the straight would be around 30mph tops. Front fork is suspended from a light motorcycle. Tires will be 2.4 wide. Rider is 200+lbs. This will be a heavy trike, if that makes any difference.
So, with my front wheel being 26", what should the rear wheels be? Since the rear axle mount and engine mount will be made to order I can use either size wheels and adjust the height at the rear to whatever is best. I don't understand the dynamics of delta trikes well enough to have an opinion. What would you do?
I can get my cyclops tires in either size and will build the wheels using 2.125 width rims. It is easier to find used rims in 26" than 24" so for that reason I would lean toward 26" in back, but if 24 is better then I'll go that way even if it means buying new rims from Husky.
Thanks for your opinion.
SB
SB
