rogergendron1
I wonder if anyone has ever tried running RC fuel in a china girl. Already mixed and ready for use in a 2 stroke. My gas RC truck and plane running on 30% nitro fuel both made over 1 hp with less than 8cc of engine displacement. A China girl would disintegrate at the RPM's an RC engine turns, might be fun though.
if you rechamber the head to have the correct squish band to run nitro...(it has a slower burn than regular gas) and upped the comp to over 14:1 .... and ran synthetic oil at a 25:1 to 32:1 mix... i cant see why not ?????
the extreem comp ratio would meen you would need a real good needle bearing and crank case seals, pluss a copper head gasket, and your motor would not last too long... would need to be rebuilt often, like after every race... but i bet it can be done just fine provided you build the motor to run on nitiro and do not expect it to last too long unless its tore down and inspected after every ride ...
one would want to run a little more oil than usual also say like 32 to 1 at least if your planning on turnning super high rpms, the more rpms you go the more oil is needed to maitain lubrication!!! so keeping all this in mind you would also have to tune your carb to run on this fuel, as it is less dense than gas it would require a smaller carb venturi and larger jets.... at least thats my theroy
