would love to see a suplier on this forum who makes a custom or modded full suspention frame with morini or denardis mounts built in.....
it could be sold as just a fram or in packages...
entry lvl would have frame and rear swing arm with some kind of inexpencive but worthy fron suspention forks and 26 in rims with v breaks
next would be frame and swing arm with upgraded front suspention and disk breaks with 26in rims
next would be the full 26 in package... frame swingarm sweet front fork dual oversized disks on 26in rims with a 7 speed derailor and handle bars levers and bottob bracket with crank and all
You could buy a full suspension bike and put it on yourself, there are 2 or 3 frames that will work. I used a GT LTS. I used the SBP shift kit so its a shifter.
The shifter works great in all conditions but I had to make a chain guide for the chain that drives the rear wheel. The chain would jump off the front sprocket in very rough terrain (Chain bounce), the guide works good but I slow down in rough terrain to avoid the hassle. Since we race on a road course I don't ride dirt much anymore because of the pain switching tires, these tires are terrible in the dirt!
Top speed is 50-52 MPH and being a shifter its quick getting up to speed. Heres a race/crash video (I have posted this a million times...lol). I never hit the highest gears because the straight isn't long enuff (7 speed and IIRC I only use up to 4th gear and hit 43-45 MPH).
The kit they show for a KTM says it comes with a 36t sprocket and that would be way too high geared for a KTM with a 26" wheel and a KTM needs to be geared much lower that a 36T. They arent at all like what you would gear a china girl. You would need at least as big as a 46T and more like a 48t.
Since they at custom motorized bikes don't know what size sprocket to use with a KTM I seriously doubt that they have mounts for a KTM that will work.
This guy says he can make ktm mounts for what ever frame you have, http://ghettobike.com/
It is a single speed, no gears. I have built 2 bikes with them, one is a single speed and the other uses an SBP shift kit (Uses rear derailler to shift).
The motor makes all it's power up high, it spools out to considerably higher rpm than a ChinaGirl therefore you need more gear reduction.
Homework bro, homework. Those morini clones run close to $500. You can build a ChinaGirl for less than that. Look into it closely before you buy something you don't need, want, or know what to do with.
