Mixing two-stroke fuel for my new motor?
The first said "Mix this bottle with 1 gal. of gas for 50:1"
the bottle contained 2.6 fl.oz.
The second said the same thing but it contained 3.2 fl.oz.
Intrigued, I asked an attendant if they knew anything about 2stroke
oil, mixtures, brands, and was assured that he did. I posed my query
only to be told that one of the oils said "Multi-mix formulea, " meaning,
he explained, that both were true! It depends, he said, on the dilution
of the oil in the container. I think I'll follow this advice;
My local TSC has some 2stroke oil, makes for interesting reading.If you look at the bottle of 2 stroke oil, you will see the correct amount to mix with a gallon of gas.
You want to mix the first tank at 20:1, then go to 24:1 for another gallon.
After that some guys go to 32:1 synthetic. I use 24:1 "regular" 2 stroke oil.
Is this a new engine? Did the guy you bought it from ride it much before you got it? Bikeguy is referring to the break in period for a new engine. First gallon second gallon etc...
128 oz. per gallon
1 0z of oil = 128 : 1 mix
4 oz of oil = 32 : 1 mix and so on.
Or use this.
Gas Oil Mixture Ratio Calculator
