Spark plug replacement
SBbiker
7
Califorinia
i replaced my plug and not much difference at all. the spark plug wire i changed and it made a huge difference
Where did you get the "spark plug wire"? Do you mean the single distributor cable that connects to the kill switch? Just asking because I bought a second hand engine with no spark plug wire?
TexasDav
528
Houston
Auto Parts store the wire screws out and is easy to replace.
Jun 25, 2008
455
Found a spark plug wire for a royal enfield on ebay, think it'll fit? type in ROYAL ENFIELD SPARK PLUG WIRE ASSEMBLY £3.95 plus £1.99 p&p should do the job dontcha think?
toytime
550
Ontario
Go to a small engine repair shop , the guy I went to had a large roll and cut off a 12 inch piece and just gave it to me for free. There must be a guy that repairs lawn mowers in your area, or motorcycles, or boats.
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
Norman
LORD VADER Moderator
Jan 16, 2008
2,606
7
38
72
pampa texas
the stock plug boot does come apart for repair as long as you don't loose the small parts you can reach in there with a small flat bladed screwdriver and remove the brass plug and take out the wire clip to get that part back inplace when it acts up. Don't be afraid to mess with it cause you can get replacement boots at the parts store and the kind of boot where you don't have to have the sparkplug with the removeable tip.
Norman
Bicycle Motor Fun
89
Warren, Michigan
The orginal Chinese spark plug that came with my engine has approximately 1/2" length of thread. I bought a NGK-B6HS for a spare, and its also the same thread length. In looking at the thread in the cyclinder head, it appears to be about 3/4" in depth. I would think that I should be using a spark plug that is made for this depth. What are your thoughts on this guys?
