worksuxxx
Ok, I have toasted two sets of crank bearings in under 12 hours. I can't seem to get the crank tight enough without allowing for any play. When I allow just a tad bit of play in the crank, I can turn the cranks with no resistance or noise. I tighten everything up, go ride, then its sloppy as ****, crazy amount of play. I go to tighten too tight to have not play, rotate the crank, too much resistance and crushes the bearing housing. This is the second crank set I have tried. This is going in a Huffy Newport if that matters. I am also using the adapters with this setup. I am using a heavy duty high temp grease for this, not specifically wheel bearing grease.
