Suzuli K10 fork watch/warning
I know that scotto,it was when bbb called it a gooseneck that the confusion set in. I know as you can read from the posts in this thread that a stem and gooseneck are the same thing on threaded forks. On threadless its a headset,right? Or is that the first big name threadless stem,Aheadset?
The K10's have a smaller threaded hole at the top of the steerer tube to bolt the triple tree clamps to, idk how you would fit a stem or a gooseneck or whatever down that small hole. I guess if you drilled it out, then you could stick a stem down in it, but I see no reason to.
Yes, stems used to be called goosenecks.....same, same. Headsets are headsets and can be for threaded or non-threaded steerer tubes. Top crown (clamp) on Suzuki fork can be reamed to accept threaded stem using threaded headset. Save that shiny chrome bolt from Suzuki fork for a rainy day ;)
