Bob, these chinagirl motors are perfect for the likes of me... I'm a real cheapskate!
They will digest just about any kind of mix oil you have on hand.
I might try the 24:1 ratio mentioned above for the first pint of fuel run through the motor, then I'd immediately switch upwards to 40 or 50 to 1.
UNLESS, I had a plan to run the Opti2 fancy spec oil.
In that case I would see what the 100:1 guys have to say, and follow that regimen.
IMO, any current oil is sufficient for these motors.
I feel break-in is a mechanical process of allowing the engine speed to vary, up & down, with changes in loading and work cycle with allowance for suitable cooling dependent on circumstances you perceive.
There is validity in the concept of breaking them in hard and fast to prevent glazing and blow-by at the rings which may not be overcome in the life of the top end.
The Alabama Fisherman and most of the top engine builders here ALL advise a certain process of tearing the new engines down for inspection before attempting to start them.
I agree Very Much !
Design, manufacturing, tolerances, and quality control are all abismal.
Inspection will most likely be critical.
Good luck to you!
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
rc
![dance1 dance1 dance1](https://motorbicycling.com/images/smilies/dfl.gif)
I agree Very Much !
Good luck to you!
rc
