49cc Gas + 2000 Watt Electric Felt MP
miked826
Selling for $3499. Yes it costs a lot but, to my horror, the parts cost alone exceeded $4000. The price spiraled out of control when I added the electric components to this already existing gas bike. This bike can run off either batteries alone or gas power or both simultaneously, as well as pedal power.
Bike:
2012 Felt MP
Motors:
Huasheng 49cc 4-Stroke C.A.R.B. Approved
Crystalyte HS3540 Direct-Drive Hub
Clutch:
Fully Automatic Centrifugal EZM Q-Matic
Batteries:
AllCell - Lithium Nickel Manganese Cobalt 48V 12.9Ah (Housed in right hand ammo can)
Phantom - LiFePo4 12V 14Ah (Housed above front fork)
Controller:
Crystalyte 40A 12 Mosfet Sensorless (2000 Watt w/Brake Regen)
Front Brake:
Tektro - Auriga E-Comp Caliper (hydraulic)
Tektro - Sintered Metallic Brake Pads
Shimano - Ice Tech Front Disk (203mm)
Rear Brake:
Crystalyte (internal electric, voltage regenerative)
Tires:
Geax - 24" x 2.3" Tattoo Rigid
Lights:
Rear Dual PDW - Danger Zone
Front 20 Watt CREE LED light mounted inside a Hella 500 light housing
Horn:
Wolo 139 Db 12V Air Horn
Throttles:
Electric - Left Hand Thumb Throttle
Gas - Right Hand Twist Throttle
Seat:
Harley Davidson bobber style, genuine leather motorcycle seat
Seat Height:
28" (fixed)
Battery Range:
Batteries alone: 25 miles (no pedaling)
With gas engine running: 75+ miles (no pedaling)
Fuel Capacity:
3/4 Gallon
Weight:
100-120 pounds (estimated)
Combined Horsepower:
4.7 Horsepower (2 Gas + 2.7 Electric)
Top Speed:
35-40 mph (level terrain, no pedaling)
Wow an actual "hybrid" bike this is so cool.
Can you charge the battery by drawing the power from the gas engine?
The main battery is charged by braking or "Brake Regen" but since your not riding the brakes all time it can only recharge about 25% of the batteries capacity. I'm about to install a 400 watt inverter to run off the front battery to recharge the main 48V battery while riding.
Of course the front battery will eventually die. That's where a rear wheel, friction driven 35 Amp, 7 lb. alternator, that I will install later, will recharge the 12V front battery. This bike project never ends. It just goes on and on and on. LOL
wow what a bike!
Thanks much.
I have had my gas throttle cable break twice at the throttle grip for one reason or another and once I was 10 miles from home. I simply disconnected the chain to the gas motor and made it home only on electric power.
2000+ miles and I've never been stranded and never had to pedal to get back home. That's what I like to call, Hybrid Redundancy. LOL
