Easy Rider
I think you should ask Grayborgusa.
They will have the answer or ask on Endless Sphere.
POPS
POPS
I'm not sure what you mean by 150mm dropouts. I'm retiring from racing and thinking about turning my Boxer into an electric if I can't find a rider for the races.The grayborg motor is very large but only fits 150mm dropouts, that could be a problem for you.
from what I've read here, the hub will handle 48v quite effectively. If you're talking about the AH rating, that's simply how long the battery will last (amp-hours, if your motor draws 2A and you have a 20AH battery, your battery will last 10 hours before needing to be recharged). Amperage is weird compared to voltage. If you put 48v to a 24v motor, it'll use 48v (over-volting, computer overclockers do it to get more power because it's forced, an electric turbocharge if you will). but you run the risk of burning it out more quickly. If you want longevity, use the rated voltage (however this could mean the difference between a 10 year lifespan vs. a 7 year life, depending on how good the build is). If your motor says it will draw 10A and you use a battery capable of 20A, the motor will only draw 10A (it's like your water pipes, your home will only take as much as is required), however if your motor says it will draw 10A and your battery is only capable of 5A (even if it can provide 2x the voltage, therefore the battery has the same wattage), then the motor will attempt to draw 10A anyway. It wont get 10A, but your battery will strain, and you run the risk of killing the battery, and maybe even blowing it up. (that last part I'm not sure if overvolting will cause a lower ampere draw or not)Here's a battery question.
First, I'm getting a Magic Pie 3 and was checking out battery packs. Will a 48v 20AH burn out the hub? Most battery packs I've seen with the kits are 10-15AH.
