Hi, yes, that is correct, jumpers 4 & 5 must be attached at all times but be sure to properly understand their use to avoid advance/retard extremes. To select the stock Jag circuit u would place jumper 4 to select the 16 ohm resistor. Jumper 5 MUST then bridge (short) the 100 ohm resistor, thus taking it out of the circuit. Alternativly, to select the more advanced timing of the international variant of the KDX CDI, jumper 4 would be placed to select the 27 ohm resistor. Jumper 5 then MUST be placed to bridge (short) the 390 ohm resistor, thus taking it out of the circuit. Jumpers 1, 2 & 3 are left off the board when you start testing for best position. First test for low RPM setting of jumpers 1 & 2 by adding either jumper 1 or jumper 2 (not both, tho it wont hurt if u do) to find which gives best low RPM power. To test for jumper 3 is the same except you are looking for best high RPM performance. For a little more flexibility in high RPM adjustment, the 0.47uf capacitor that isnt on a jumper may also be put on a jumper to earth. Hope this all helps. Cheers
