Ok, I looked around and didn't like any of the current hub adapters for the rear sprocket... plus I was **** bent on using the original New departure hub that I have... So, I made my own. Here's how...
I machined a couple pieces 6" diameter. The piece on the left is going on the outside of the wheel and the sprocket will bolt to it... the piece on the right will clamp around the hub.
Here's the piece clamped around the hub...
Here I bolted a standard 130mm single speed / BMX chainring onto the other piece... I ended up re-bolting it onto the backside eventually to get a proper chain line
