bigbutterbean
I bought a pair of these forks for my latest build, and I thought I would post a thread about the modifications I have done to fit these on my frame. Here is a link to the forks for anyone who is interested: http://www.ebay.com/itm/220986587363?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 The first thing you should be aware of is that this version of these forks come with a handlebar clamp for 3/4" bars, and most bicycle bars are 7/8. They sell a version with a 7/8 handlebar clamp, but it costs $20 more. So it is necessary to make the handlebar clamp wider to accept bicycle bars. I did this using a dremel. I started with a grinding bit, but changed to a cutoff wheel and reamed it out that way. It worked out well, and I now have a nice pair of cruiser bars mounted up. Another thing is that these forks have pretty soft damping, and the oil that comes in them is very light. I don't know what weight it was, but I emptied it from the fork into a measuring cup to see how much was in there, and it was about 2 ounces. To me that didn't seem like enough, so I added 4 ounces of 10w30 to each fork after emptying the oil that came in them. Another thing I did to stiffen them up a bit was turn the spring perches upside down. In layman's terms, the spring perches are these plastic washers that when installed from the factory seat into the top of the springs and I suppose keep the springs from digging into the bottom trees. Turning them around makes them not seat into the springs, allowing the springs to be compressed about 1" further than stock, stiffening them up nicely. They come with a 1" steerer tube, but you can't use a regular crown nut on the headset, because the top tree bolts to the steerer tube, and a crown nut would make the top tree sit at the wrong angle. Here is how I installed my headset. I first put the cone nut on, then a flat washer, then a threaded washer (sort of like the cone nut, but flat), and then I used a crown nut, but I cut the crown part off so it can be threaded down past the top of the steerer tube. The steere tube is also 6.5" in length, a bit longer than my head tube, but I saw no reason to cut it shorter. Considering the way I installed my headset and the fact that the top tree also bolts to the steerer tube, I saw no reason to cut it to length. The frame I am using is an American made Schwinn cantilever frame, I think I forgot to mention that. The only other modification I am making is to cut the dropouts. Because they are motorcycle forks and I guess motorcycle wheels have sealed bearings and therefore an axle can be slid through, the dropouts on these forks are completely round and enclosed, in other words they cant be picked up and slid onto the wheel like a regular bicycle fork. So I cut the dropouts so they can be slid over the axle. I used a dremel and a cutoff wheel to cut a small section off the dropouts, then a grinding bit to widen the space it left because at first it wasn't wide enough to put an axle through. It worked good, and there is still plenty left of the dropouts for the axle nuts to have good surface contact. Lastly, these forks are much wider than a bicycle fork, so a standard front axle most likely will not reach both dropouts and you'll need a longer axle. I took the axle out of a mountain bike wheel, and I'm in the process of fitting it up to my Worksman front wheel. There might be different ways to make some of these modifications, but this is what I've done and I hope this helps anyone considering the K10 forks. For $39 plus shipping, they are one heck of a deal and they are well worth the relatively small amount of modification needed to get them to work on a bicycle.
