ha ha, a transmission for a 212 consists of a little bit more than a sprocket and a chain. First off you need a clutch. Secondly, you need multiple gears to get enough reduction to get a useable final drive. A transmission for a 212 is either going to consist of a belt primary and chain secondary, which can be something like the qmatic or a cvt drive, or a jackshaft, which is chain primary and secondary. You cant run one sprocket on the engine and another on the rear wheel with just one chain like you do on a china kit, because you wont have enough reduction. Most people use centrifugal clutches on the Predator engines, although I do believe an EZM silent drive will bolt right up to a 99cc, but silent drives are hard to find nowadays because they are not in production. But I dont think a silent drive will fit on a 212 anyway. There is a member here who built an in-frame friction drive with a 99cc predator using a belt straight from the shaft to the roller, but that wont work with chain drive. So no, a transmission isn't as easy as you seem to think it is. Yes, a motor mount can be made with a welder and some angle iron, several members here have done that, but again, it takes know-how. Linking up a throttle is not terribly difficult either, but again, know-how. Installing a Predator of any size in a bicycle is NOWHERE NEAR as easy as installing a china kit. With china kits, most everything is already done for you, its a simple matter of bolting everything up and making a few adjustments. Installing a Predator requires technical know-how and may require custom parts that you may have to fabricate yourself. Again I ask, have you yourself built a bike with a Predator engine?
