MitchP
I have a Grubee GT5. Using 87 octane fuel w/ 10% ethanol (I live in Cali) and redline 2 stroke oil. NT carb. 20:1/exact measurement
The problem I am having is that the bike has been starting less and less. At first it wouldn't then I got the tip to remove the cap on the exhaust. And it worked, and that's how she's been running since I got it. I put a 2-quarter inch holes in the cap to relieve the back pressure. These are just the things I have done.
A week ago it started OK. Then after a bit it would sputter while running. Like the motor would lurch and then try to quit. It's gotten worse to the point that the bike will just not start. It may make the crackle/pop of the exhaust igniting and might even start but it dies immediately. Won't idle either.
I've been good about shutting off the fuel when she's parked.
Some notes-
-Taking the cap off today I noticed oil in the exhaust tube. Like it's oil, not burnt
but I can rub it between my fingers.
-There is burnt oil/gas coming from the spark plug. It's running down the head. I'm sure because I looked in that space between the head and the (piston wall?)
And it was clean. I tightened it a little.
-I torqued down the head also to about 8lbs pressure with wrench doo-higgy.
-I undid the carb to clean up the cables. Is there something I botched? I will check anyways.
It's cold. Usually 40-50 degrees if it's not raining. Today I was off to Ace to make a cool adjustable flow exhaust cap.
I have an NGK B6 and new plug coming. My general feeling has been a deep sigh.
Some notes-
