MotoMagz
Why does this mount have 2 sets of mounting slots??? http://www.ebay.com/itm/140690643615?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Not sure, but I just bought one of these exact mounts, and can tell you that neither set of holes are for a harbor freight 79cc engine. I am going to have to redrill, and unfortunately, it seems my new holes will be very close to two of the slots.
Wish I had seen this one before purchasing:
http://www.bicycle-engines.com/Black-V-Frame-Mounting-Plate-Kit.html
Another geometry related question about these 4 stroke mounts-
Since the angles of the downtube and seat tube vary from frame to frame, as do the tubing diameters, how do these 4 stroke mounts accomodate all the different frame variations?
You don't want to use this eBay motor mount especially with the 79cc engine. We built some bikes with that same mount using the 49cc 4-stoke. The center plate with the two sets of slotted holes is made from some really thin material. All but one of those mounts we used cracked, bent and failed. The torque from the 79cc engine will tear up that mount in no time.
The motor mount from bicycle-engines.com that atombikes posted looks to be the better mount that uses thicker material for that center plate. We've used several of those with no issues on the 49cc engines.
The 79cc engine is a torque monster compared to the 49cc. Some upgrades from the typical off the shelf parts are needed. The 79cc engine will put your building skills to the test like the 49cc engine never could.
You most sand/file it to fit the angle of your tubing.At least that is what I have did in the past.
Birddog (bicycle engines) is a national distributor for grubee,
I would think the mount would be Grubee![]()
I am looking for a plate for the doodlebug 97cc not the 79cc but I do see your point.Does your mount fit the doodlebug????
We built this 99cc bike for a customer using our engine plate and the frame mounts from the bicycle-engines mounting kit.
I just checked our engine plate against a 97cc Doodlebug engine and the bolt holes line up. When we get around to building a bike with one of these engines we will use our motor plate and weld two parallel pieces of flat stock in the frame for the plate to sit on. We use 1/4" thick flat stock. Then we drill the holes in the flat stock so the engine plate can be secured to it. This makes a nice solid setup and its adjustable for chain tension.
Some people do not have access to a welder and need a bolt-in option. This is when we combine our engine plate with the frame mounts from a 49cc setup. We use the Black V-Frame Mounting Mounting Plate Kit from www.bicycle-engines.com. Replace the engine plate from the bicycle-engines kit with our engine plate and bolt it in.
