WCC SO-CAL Special Frame Build....
CCC-
Wow, fantastic build!
Question about your pedal side cranks (pic attached). Are you running a 5/8" jackshaft with reamed moped cranks in a bottom bracket shell? Smart- I thought it was my original idea for a cheap wide crank set...oh well.
If so, are those 1.375" OD/ .625" ID bearings in the bottom bracket? And then you use some sort of machined adapter for the bottom bracket shell?
attachment.php
What crankset is this?
