Gee,Harry...Those cylinders would look good as a "V"Twin set-up!...Just have ta make a sweet crankcase!...Make a nice Boardie engine too!....Tigmaster....
The flywheel doesn't it have magnetic pickup to fire the electronic ignition? That is a Victa? what year and cc is this one? .............Curt
That's a good looking engine Harry,
Wish those were common in the states!
-Kirk
I would try adapting an igniton from a small motorcycle engine. Most all of them use a small round plate with points or sensor, with a hole in the center, for the cam or rotor for the sensor.
Yes you will need a battery and ignition coil too, but you can take them from the donor motorcycle. Personaly, I would try to use points ignition for it's simplicity.
hary check out roll youre own CDI on this forum ken![]()
