I've got a chinese 2 stroke that, I believe, has a broken crank arm. I'm trying to pull the gears; however, the small gear has a large screw in the center that I need to remove first. I can't get that screw out.
Which direction is the screw meant to be turned to remove it?
What's the proper way to hold the large/small gears in place to prevent them from turning when I attempt to remove the screw?
