kayak26143
im wondering if anyone can give me any info about ordering this kit from gasbike.net
GRUBEE 2011 SkyHawk GT5 66cc/80cc Angle Fire Slant Head Bike Motor Kit, Standard Finish, comes standard with the cns carb
I have never bought one of these before and know nothing about any of the dealers. im looking for the least hassle all around customer service ect. first motorized bike also. im looking at a 26in cruiser to mount this in.
is this a good company to order from and is it a good kit. or am i just stuck with i hope it comes and everything works ok, is there any concerns or problems with the dealer and or kit that i should be aware of before i send them any money any info would be great thanks
		 ) I have heard said the needle only has one slot in the newest CNS which is probably the biggest negative for this version of the carb. I am not sure if the 5 slot needle from the previous version of the CNS will fit in there. The previous version of the CNS has the red plastic air filter. I hate that air filter (though it is extremely low profile which might be a big plus on some bikes) it has a foam insert that likes to clog up with oily blowback from the carb and can eventually bogg you down a bit, so I found myself cleaning it a lot more than I wanted. The aftermarket low profile cone air filter from SickBikeParts solved that issue for me nicely. This older red plastic air filter version of the CNS carb has a 5 slot needle and no caps on any adjustment screws. There was also an even older version CNS carb but I doubt any kits with that carb are still around. One common complaint about any version of the CNS carb is it requires a spacer around the intake to clamp it down because the throat is larger than the other carbs. The older spacers were extremely brittle, you're lucky to get the carb mounted once without breaking it, which is extremely frustrating when working with something brand new. The newer carbs I have seen have had the spacer made with a much better material. That said, the spacers can be made easily enough for next to nothing from a section of PVC water pipe or copper tubing.
