How does yours Idle Sd?
I didn't even really try to tune itmuch at all I put it on the motor it came with "Skyhawk" ran it I wasn't getting the desired results, so I put on a stock one I wanted to see if it was the carb or something else causing the issue I was having. I got much better results with the stock carb so I just left it on there "Not that this is going to help me trade or sell it posting this "tid bit" but the fact are the facts, be them as they may
idles perfect warm
when engine is cold, like overnight it takes like 5 min of high idle before it will idle
But I had asked about that here and someone said thats normal
So once it warms up mine can idle super low if I like
But yeah stock carb would idle perfect hot or cold but of course its different too
I just added a smaller filter, accidentally over oiled it but once cleaned out it runs really strong now
I also changed my mix down to 25:1 from 32:1 I needed to be a touch leaner because plug was to black
Just easier then filling and drilling the jet again
I will make a idle video today all I can say is the carb and a newer 4 tooth larger sprocket my bike is set. No more pedaling up hills anymore the carb is stronger then stock, and im sure the gearing change helped too
and I think that smaller filter, or because its oiled more it even runs better now too
Just need to check the plug again but I think maybe I hit the sweet spot
