Rocky: Expansion chambers vary in price drastically across the board. Moped pipes can cost anywhere from $50-220 and more expensive isn't 'Better'.
Pipe geometry is what effects Everything, and for his processes and materials, his cost may be higher than SBP's. Furthermore, SBP's pipes seem to have pretty insane header lengths, Arrow's pipes look to be much nicer for mid-to-high RPMs.
I'd have to see the blueprints to be certain, but if it were my $, I'd spend it on the newcomer.
I ordered two of these on Tuesday night & I got them both today! Lightning fast shipping & a quality product!
I even had time to install one & test it a little.
Well did it help your engine? What changes do you see in the powerband?
Here's my first post about how it worked... I should have just bolted it on & tested it without doing any mods; but i didn't...
What I did right out of the gate was to remove the cylinder & cut a wide groove down the inside of the cylinder (from the base of the intake port straight down) to keep the intake manifold open to the crank case 100% of the time.
What I found from doing this was that the engine lost 80% of it low end power, but it gained noticable power from the mid RPMs all the way to full RPMs. It didn't gain any top speed, but now it has a lot more power! With the revs up, it can now climb hills that it couldn't before.
I'm going to experiment more when I get some time.
 OMG this thing is AWESOME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! the bike runs SO and i mean SOOOOO much smoother quieter and more POWERFULL than ever before. Before it sounded like a ticked off weedeater now the engine just sounds like a moped. I could not be happier with this purchase, if you are thinking about getting one just go ahead because you WILL NOT regret it. well one more thing after riding around i found out that i do not have a self oiled air filter anymore, no biggie thats what they make air filter oil for right guys?
