BarelyAWake
Much has been posted about brakes & some advise upgrading from coaster brakes to some type of rim brakes at least, to improve stopping power of course...
Thing is, I'm not that big a fan of rim brakes TBH - they don't work as well when wet, don't work at all in the ice & snow, they're a pain to keep adjusted properly and without a doubt have the worst wear rate of any type of braking system ('cept maybe sneakers lol) and by "wear rate" I'm not talkin' bout just the pads, while that can be made manageable with a decent set, it's the wear on the rims that's problematic - which is a far more costly & dangerous issue;
Yeppers, that's a six inch chunk missing outa the side of my rim. No, I didn't crash, but it was quite exciting there fer a few. I didn't crush it w/my brakes, all it took was a slight bump & the excess pressure blew the side wall across the road with a very impressive bang. I was lucky in a coupla ways, it just happened to be my rear rim & as I wasn't braking at the time and didn't try to brake the wheel that just had a blow-out - it didn't lock up on me & I just coasted to a stop, if a squirrely one.
Granted that's a crappy single wall alloy rim & I knew it was gettin' sketchy, even though that particular rim only has roughly 5000 miles on it - but even if it was a double wall I suspect it'd be well past it's safety margin & would need replacing, given how thin the side walls have become.
So... be warned. If you've rim brakes, or you're thinking about upgrading from a coaster brake and/or replacing the rims on your motorized bicycle, you may wish to consider spending just a little bit more and get a decent set of double wall rims with drum or disk brakes. If you can't or don't want to for w/e reason, remember to check your rims for wear periodically at least.
There's a reason why mopeds & whatnot don't use rim brakes & I think the above illustrates that quite well
