MEASURE TWICE
Electronic Ignition Modules convert to breakerless system without magnetic pickup
It seem I thought there was a need for a magnetic or some other kind of feed back to get the timing on these type of modules that lack having either a light or magnetism pickup associated with the crankshaft.
I was wrong I am guessing from the fact that the single cylinder engines that had mechanical points, only have them for opening the primary circuit to get the flyback effect in the magneto to create the high tension delivery to the sparkplug.
The flywheel magnet passing by the magneto is where the timing really is and there is no adjustment. If the key way get damaged that is the way the timing can change and the engine won't run.
The adjustments of the points must be considered in to adjustment 0.020" for the delay after the flywheel magnet passes the magneto. This means the electronic module does the same amount of preset delay to match and there might also be an automatic adjustment for advance. But unlike like the vacuum systems on old cars acting on the diaphragm to change the dwell, if it is to be electronic without a magnetic pickup, maybe it can sense the rpm from the charge as it appears on the primary and then disappears again.
My Briggs and Stratton Model 80202 0430 01 is I think a 3hp 4 stroke and although it works and am considering getting the module to convert it. The kind that also has you still needing to have a magneto that the engine came with. There is no sensor pickup as some engines that came that way already have.
Does this seem correct?
MT
MT
