Finally some progress... the tank took forever to finish... First filling some of the uneven areas with autobody lead, then coat with body filler to smooth out curves. Followed by primer and several coats of $3 Colonial Red from Home Depot.
here's leading going on, looks ugly, but its easily workable with large files.
![](/proxy.php?image=http%3A%2F%2Fimg32.imageshack.us%2Fimg32%2F9400%2Fma148.jpg&hash=7fb525b9cfd729a7fdb1b0b242eda76a)
Tank looks a bit hazy, its the crappy Blackberry... It is actually shiny, it might help to keep my fingers off the lense?
Took the same rattlecan and sprayed light, tail light, horn and front forks. I modified and welded the front light attachement to the forks. Tank has some marks of "re-work" in this picture. It was drying at height of 6ft and I dropped the sucker on garage floor. Needless to say, it got messed up and I had to do some "damage control". It's OK now, but I lost many hours (and beers).
Found some cool spark plug wire, which is cloth wrapped and old style "screw on" brass nut. Propably not a good idea to run this bike in rain??
Great thing about this spark plug attachement is that it is very easy to check if it has spark, I can reach it with my left hand! and judging on the amount of sudden wrinkles on my face, you can determine the condition of the spark.
Next is wiring and controls (brake/throttle). Then frame to be finished, I need to cut thicker rear drop outs. More painting and later some pin striping....
Wheels are not laced yet, so that will take LOTS of time. The 12 gauge spokes are obviously too long, so I have to get a 0.45x2.5mm die to cut threads. All 72 of them, unless I find shorter spokes soon...
