magrider
Goat I'm on the same page. http://www.tomarengineering.com/
I hear you the winter months can be a burden. Hang in there warmer weather is coming!! Looking forward to your impression of your new clutchHi guys.
There currently is winter in Germany and my Themometer shows
At -17 degrees. So I'll dispense with the test drive and make it until spring. You have to wait a bit before I can write you about the test drive with the new clutch was.
I would like to once again participate with you in a race
(Death Race).
Unfortunately, the distance separating us.
But there are pictures and videos, so I'm mentally too.
Yes, the clutch is not cheap, but what does not do anything for his hobby. In this sense, all the best till next time
Greetings Jean![]()
I thought I read somewhere these were made in the U.S.A. ?Goat I'm on the same page. http://www.tomarengineering.com/
I will have to do a compression check . My compression checker kit is not accurate I found out.. going to have to purchase a new one.You say you want to pimp out your S6C? I have a contact that does head and port work CORRECTLY. You will gain about 10% hp. Have you done a compression check on that motor yet? I would like to see what that liquid cooled head is set at.150 to 160 psl is optimum.
I just ordered a MORINI 21MM CARBURETOR and a S6 High Performance Complete Clutch Kit from Morini Franco USA. I'm told that the 21mm carb will increase of over rev on the motor (increase your RPM range). www.munnracing.com are the guys who do the head and port work. I would stay clear of Rob's Racing Engines. I feel like I got taken by this guy.I hear you the winter months can be a burden. Hang in there warmer weather is coming!! Looking forward to your impression of your new clutch
I spoke to your contact once a while back I have mean plans brewing
My S6S with a larger 21mm phbg Dellorto may be running higher compression than stock with just the carburetor upgrade. Reason I say this is because I have peaked inside my S6S 9.4 hp. and my S6T 5.8 hp.
Their heads jugs pistons etc look identical. The only difference are their ignition, smaller carburetor and smaller reed valves. What I want to say is just by making these breath a little better raises the compression because a bigger breath of air is more air to compress. Like turbo charging a car.
The S6T 5.8 I have came with a very restrictive reed valve ''single wall 3 peddle medal '' and a very restrictive small bore carburetor. Verses a 4 peddle on two walls carbon fiber.
My S6C is getting a 21mm Del for sure!! The S6C must have a reworked head don't know? I have not peaked in one yet. I also noticed it comes with the grippa style 3 shoe clutch. Which has better surface area to it. Instead of a clutch pad ''stone face'' with dimples it a has no dimples ''a flat surface'' ''face'' offering more surface grabbing area.
My S6S has the dimpled one and has actually done really well for me!
S6C INTAKE Reed valve w/4 flaps in crankcase COMPRESSION RATIO 15,5 +/- 0,5 : 1
S6S INTAKE Reed valve w/4 flaps in crankcase COMPRESSION RATIO 14,5 +/- 0,5 : 1
S6T DISPLACEMENT 49,8 cc INTAKE Reed valve w/3 flaps in crankcase
COMPRESSION RATIO 12,5 +/- 0,5 : 1
I forgot to say I measured just now the 3 shoe bell. Looks the same for the grippa style as well 84mm inside 89mm outside.. The two shoe clutch bell measures the same except it is narrower leaving part of a 3 shoe assembly hanging out a little bit if some one tries it. That and a new 2 shoe bell has a raised ridge going down the center of the clutch shoe surface for some reason?Hello guys. Goat Herder.
Thank you for your quick help!
Yes, the clutch bell is 84mm inside and outside of 89 mm.
