trevpiee
So I just received the new 2011 4g w/ h 142f engine and am running into trouble installing the trans onto the engine.
The first problem was the key for the clutch pack did not fit.. I tried jamming into the slot but I ended up having to shave it down a bit to get it to fit.
Not a big deal but then when I went to install the 4g, I noticed screws were too long to completely tighten it to the engine. I don't know if you can really tell in this pic.
This is all the hardware that came with the 4g + engine
Moving along with my troubles, even with the 4g completely tight up against the engine, the large belt pulley is coming into contact with the clutch as seen in this pic.
Lastly, although it states in the manual that you need to add oil to the engine before installing the 4g, i did not realize that the new model would prevent you from removing the dipstick with the trans installed.
I haven't seen anyone else mention any of these problems. I have built up several bikes using last years 4g with the 142f engine, and did not come across any major problems... Am I missing something here... or just doing something completely wrong??
