cobrafreak
I am familur with welding steel. I have a stick arc welder and a gas-less wire feed flux core welder. Is there a way to weld aluminum with these two types of welders or do I need to get another type? Thanks.
You will have to look for another method. I am using a tig welder to steel, alum and stainless. I really like working with alum as it's easy to cut and fab parts up.
What are you trying to weld?
I´m got some inputs on other ways.....but havent tested it yet by my self, and ain´t shure this could be used on bicycle fabbin´.....
Using a torch to melt/weld zinc to make joints. Its said its great on thinner material to make a joint, when done right the alu breaks outside of the "weld" on bending test.....
And zinc is easy available & cheap f.ex. as corrosion anodes on boats...
planned to try it on a 50s sunvisor who got som breaks, but havent got time and schedule for it yet.
A MIG (wire feed) machine will require a teflon liner to allow the aluminum to slide easily. Trying to use a steel spiral liner will assure that there will be binding.you can use a mig ( with a good spool attachment )
Don,t even bother trying the aluminum wire thru the mig itself .
Its supposed to work ... but doesn't , and the aluminum wire is soft and flimsy ... it will bunch up on the roller inside the mig ... if it melts inside the wire feed line .. good luck getting it out .
