Not sure if this is the proper area to post but thought it may be best.
Well here goes, built my bike with a used craiglsit purchase 66cc. Bike ran great for 8 months. no issues besides the normal loosening of bolts. One day at WOT motor just died, kind of like it lost all spark.Bike would sound like it wanted to run while peddling but no "POP". Pulled the plug and found a very rich coloration. Changed plug, changed oil ratio from 25-1 to 30-1 and didnt start, changed cdi, didnt start. Had another unknown 66cc motor on the bench that was in almost perfect condition. Swapped it out and BANG away I went. Ran extremely well for about a 20 min ride and then bluhhhhh. Same issue. Again I checked plug and it was very rich. with this new motor ( pictured below) I have now done the exact same swaps of parts and found no improvement. I did however find that this motor did not have a head gasket, only some blue sealent that was barely there. so i installed a head gasket. As you can see by the pictures, I did begin with an intake manifold that made the carb level, I then tryed 2 other intakes wich made the carb not level. i am currently back to level. If there are any more pictures that would be helpfull to pinpoint an issue please let me know. I have done the following in an attempt to repair.
1) new plug
2) new CDI
3) new magneto
4) new head gasket
5) checked jet for clogs and cleaned carb (really wasnt dirty)
6) tried to run without exhaust and with standard pipe
7) scoured motor for any possible air leaks (found none)
Note: The only part that was on both motors was the NT carb and please excuse the taped up cdi and the bare wires, I wanted to show my wiring conection and mount the cdi for quick removal while figuring out my issue. Thank you in advance for your help!
![:-|| :-|| :-||](https://motorbicycling.com/images/smilies/Waa.gif)
1) new plug
2) new CDI
3) new magneto
4) new head gasket
