DuctTapedGoat
Quickie parts list for the CDI:
Diodes: 1000 PIV 3A
Resistors: 18 and 82 Ohm 1/2W
Capacitor: 2uf 600V Film/Foil Polypropylene
SCR: 1000V 3A
Due to the wide variety of ignition coils that can be used it is better to overrate the components to be safe, although for the most part, you can use just about any parts that you may have lying around.
The component values are not set in stone; for example, I used 400 PIV 1A diodes in my prototypes with no problems.
I used an SCR that is just too big for the purpose (600V 63A, inverter grade), but that is what I had lying around, so I threw it in.
An old TV with a CRT should provide all of the parts except maybe for the SCR, although some TVs used an SCR in the power supply circuit. Heck, you might even be able to use the flyback transformer as your ignition coil! (I'm gonna try it!)
So, I've got an old flyback transformer from an RPTV - I agree, we gotta try it out. I'm still hunting locally for a pot that can handle high voltage and/or an SCR. Smallest I have that's high tolerance is 1500V 8A, and I dunno about that one.
