fattmeeney
I purchased new piston, rings and bearings to improve compression in the hunt for optimium performance/operation. I work with access to a complete machine shop, with all possible machining,tooling and metal finishing goodies one could think of, I am qualified and capable of using said machine's/tools.
After purchasing the parts (won't name name's till know what their prepaired to do about it all) I peddled to work and did the install throughout a 8 hour shift, I used all new hand made gaskets, high tensile caphead bolts, double checked everything and was using mic's to ensure things were within .02 of a mm, I used the company spec's to get measurements. The bore was honed, 2stroke oil was used on the bore to aid install.
....long story short after a warm-up of about 3-5mins, I gently putted up a hill whilst peddling, coasted over it not going over 4500rpm, I rolled down the hill used brakes to controll mine and engine speed, let go of brakes, hit the brakes and BANG, rear wheel lock up complete seize....
got home biggest piece of ring I've found so far is the size of a matchhead, there's powdery **** stuck in (install) oil residue on the head. The whole lot is seized, piston in sleeve. I haven't removed the cyl. head as the conrod is still attached, I don't know if it's bent though.
What I want to know is has anyone had a similar experience, know what might have caused it, Personally I beleive it was a manufacturing fault as I have installed many pistons in cars, bikes (both 2 and 4 stroke) and little moddle engines. Never had drama's before, nothing like this
will keep posted as to company's response and resolution, Will name and shame if a fair conclusion is not reached.
