My Eagle BTR
spstar
Here is the start of my third build, Pirate Cycle guys hooked me up with a tank from Pat and a rear hub drive and sprocket.
It looks like it s going to be a tight fit
Going to paint in Maroon tank included w/gold leaf Logo on the tank is the plan
cream tires.
Scot
how did you get your worksman without a rear drum brake ?, they told me that if you order the front drum brake , you have to order it with the rear drum brake as well , i want a 3 or a 7 speed rear end coaster brake and a drum brake in the front ....
Clean bike, I like it. Say, where do you get those hub adapters that clamp around the hub and provide a mount for the chain ring. I'd like to use something like that on another build.
First post tells where he got it from, Pirate Cycles. Although there a several different hub adapters being made by several members.
Thanks. It solves a lot of issues. Glad someone is making them.
Isn't sportscarpat making some that look pretty indestructible? i think if you look in the swap and shop section and look for posts by Pat you will see it, he has a bunch of pics and one with a micrometer so you can see how thick and sturdy the metal is...
check it out.
@moon I ordered it thru my local bike shop we did it on line it's a crusier not the newsboy but the same as it without fenders
i thought what the heck support your business and they were easy to deal with
And yes I did get the adapter from Pirate It's not Pat's I believe its a maniac
