Hi all, After lurking for some time now I finally ordered a 60cc 2 stroke kit and am building up a boardie-style bike to put it on. I've chopped up an old beach cruiser which used to be my mom's and have stretched the frame by about 8cm and flipped the handlebars. I'm planning on cutting the bars a bit shorter, and will will be adding a rear motor mount and middle frame tube once I have the motor positioning like I want it. Here's some photos of the build thus far:
After cutting the frame in two I welded a couple of plates to the front half's tubes so I'd know they were square, then cut the bit of top tube out of the way so I could fit in a new one. Then I clamped both halves between bits of 1x4 and shimmed both sides with a couple of small wrenches for shims to fine tune it. This method of keeping it all square worked better than I expected.
New top tube welded in place with splints still holding bottom together.
After getting the frame back in once piece, I tossed it together for a spin around the block. Not too bad.
After about 10min of putting bits together from the box. I was surprised how much was left unassembled.
Motor rough fit
I'm not sure I'm happy with the straight addition to the down tube since it makes the motor seem to ride a little high for the middle tube to clear the spark plug and throttle cable. This is my first build of this kind, so if anyone has any good advice I'm all ears.
![](/proxy.php?image=http%3A%2F%2Ffarm4.static.flickr.com%2F3278%2F5717146818_0b2e540053_z.jpg&hash=a067ad4da4eb457cb3f681ed8d5b7ddd)
![](/proxy.php?image=http%3A%2F%2Ffarm3.static.flickr.com%2F2173%2F5717147710_5aecfdabd0_z.jpg&hash=0db359a95e44b74c9408b97710ec8542)
![](/proxy.php?image=http%3A%2F%2Ffarm3.static.flickr.com%2F2577%2F5717148152_92a7bfb7d3_z.jpg&hash=908d98aaddb6932ad3a4a1246fe7ec4b)
![](/proxy.php?image=http%3A%2F%2Ffarm4.static.flickr.com%2F3335%2F5716583421_e0bf71ec43_z.jpg&hash=c7aeb69ca7c438b5136a7ff1032986f3)
![](/proxy.php?image=http%3A%2F%2Ffarm3.static.flickr.com%2F2148%2F5716584193_a45d8383d6_z.jpg&hash=38a83e92c4dd4ea097c79beebb1124d1)
Motor rough fit
