maybe he has a different bikeI'd imagine it's because the motor is REALLY high up.
I think you've got a real nice build going. I like the clean look of the way the motor is mounted.
I'm soon to start my third build with a frame shaped similar to yours. I'm planning to find one of these offset intake manifolds to install on mine. I think you're going to need one too.
What size tire does your bike have? Is your problem with the tire rubing the chain?
What I meant was how wide is the tire? What's it say on the side of the tire? Is that what your problem is, the tire rubs the chain?The tires are 29 inch
the bike is huge
I had a problem with the chain rubbing on the lower fork of a Op Roller build I made.Also wanted to give an update that the chain DOES rub the chainstay on the bottom of the frame and the top
but with 1 chain roller included in the kit you can stop either 1 that you choose
So what i'm planning on doing is putting the roller on the top and slightly bending the chainstay out some on the bottom.
That was the first thing I did. It looks a million times better doesn't it?![]()
here is naked now
Try here. It's about half way down the page.Where do you get the offset intakes?![]()
