MotorNut123
That is definitely a pipe that I want to get. Just wondering if it would clear the cranks
(smiles at SB) Considering the power gain I would guess you could add 4 Briggs and Straton mufflers on and it would be like spilling a little water from a bucket full of improvement water carrying it in from the well ;-}Pablo,
With the little B&S type add on muffler, is there any appreciable loss in power?
SB
All the reviews say its quiet. Is it really?
I didn't re-jet the CNS66 carb on the 66cc 2010 Skyhawk, I just set the needle clip to the bottom for richest mix and it's dandy.To re-ask the original question, did any of you guys re-jet when adding the sbp pipe? Peace
-LS
The close to the top you set your needle, the LEANER the mix, hence more air less fuel. More air runs hotter.Right now I'm running at the second from top notch and I usually like it that way with the NT's so I may get a bigger jet -LS
