Sportsman Sprocket Adapters
sportscarpat
Jun 25, 2009
1,845
487
83
california
I have just a few prototype units of my sprocket adapters left. These are what I consider the standard size which is a 40t sprocket with the adapter sized for a Shimano 110 hub. $80 plus shipping. These are perfectly balanced, offer greater clamping force and do not interfer with the hubs brake arm. I will also have more in two weeks.
DSC06212 by Sportsman Flyer, on Flickr
matthurd
817
2
manchester NH
i have one of these and can say they are awesome, bolted on real easy tightened it up and it grabbed the wheel, and made the alignment much easier to get perfect then any rag joint ever could.
Venice Motor Bikes
Mar 20, 2008
7,362
2,052
Los Angeles, CA.
I already have three of these on some of my bikes, & I have many more on the way...
There were many of us who gave Pat every idea we could think of to make these hub adapters the best product possible.
These are so much nicer than the other ones in every way; & the three piece design is a truely tremendous improvement.
scotto-
Custom 4-Stroke Bike Builder
Jun 3, 2010
6,505
25
38
Ridin' inSane Diego, CA.
Hey Pat, was just wondering if you're going to be producing sprockets/adapt. in larger sizes, like say 60 tooth? Also if the adapters will be sized for different size hubs......seems like the 3-piece design might be a little more flexible tolerance wise than say a 2-piece? Just wondering......and nice job by the way.
Thanks,
scotto-
dnut
sportscarpat
Jun 25, 2009
1,845
487
83
california
Thanks,
scotto-
dnut
Hi Scotto,
Yes I will be making different sizes, probably the next time around. As for sprockets that's the easy part. My sprocket supplier (that is all they make) will make any size I need with just a couple day turn around time for around $30 retail. I have a 66t being cut right now and a 56t was just ordered. Just let me know what size you need. With three pieces the bore is more flexible than a two piece design. An arc is more forgiving than half a circle.
Pat
scotto-
Jun 3, 2010
6,505
25
38
Thanks much Pat,
I'll def be in contact with you soon, appreciate the info and quick response.
Cheers,
scotto-
Hi Scotto,
Pat
flybytaco
Metal Molding Madman
Oct 17, 2009
1,170
8
seekonk MASS
cool pat. i read you were doing diffrent sizes next time around? all the adaps i need now are custom sized.
also congrats on your new desighn. I hope you do well in your venture
sportscarpat
Jun 25, 2009
1,845
487
83
california
I need to pick up a few of the other hubs to get the sizing right and will work from there, so yes I will offer more sizes. Maybe I should run off some blanks with just a pilot hole so the oddball one-off sizes can be quickly made. I may have already mentioned this but custom sprocket sizes are easily made so if anyone needs a larger sprocket size for the four stroke applications that is easily handled.
Pat
