I don't mind the shroud on the HF so painted mine. It being metal makes a difference, I guess. I removed mine to paint it and don't see how that should affect the pull start. Just leave the pull start alone... no need to remove it in order to paint.What about the shroud on the HF ? anyone take one off and put it back on successfully...just asking because I want to paint or remove mine but another guy had the pull start come apart upon removal.
Cheers
Greybeard,I'd planned on using a Trail Tech temp gauge in cylinder head temp mode, and removing the shrouds after break-in. I had a turbo Corvair that occasionally saw 500 degrees cylinder head temps when it was really being abused, and the airplane I fly is redlined at 400 and I try to lean it out so it cruises at 385. You really don't want an airplane engine to stick up 'cause you can't pull over to the side of the road very easy. I remember some old Harly flatheads with gauges and they went to 500 and the guys didn't get nervous until they were above 475.
Many old Briggs motors spent most of their lives pushing scooters and bikes without the shrouds. Even when they were still and idling, they weren't under load so they didn't get hot very fast. A stationary engine working hard needs the air moving accross it. I don't know how fast the air is moving, but it won't push your hand very hard.
When you put a coffee can shroud around the flywheel, and it fits tight and reduces the airflow, it also reduces the power loss. Putting you hand over either the input or output of your shopvac will show you what happens. There will be less energy loss because the fan isnt doing any work. It no longer has to pull air in, creating a vacumm, or push it out, pressure. It just moves the same air round and round at the same speed.
Interesting concept. Do you recall your uncle's bike having pedals, or was the foot lever in place of the pedals?Back when very young, my uncle had converted a bicycle to a four stroke engine he had taken off a lawn mower. Drove the wheel with a belt that you had to apply tension with a foot lever.
Wayne,Hey, why not put a large louver in the tomato can, aimed at the cylinder . Would be just like a Solex shroud. They have no cylinder tin, and the shroud vent on them blows air at the cylinder when the bike is not moving.
Some of the new Harley cruisers with all the fairings, have electric fans to help cool the rear cylinder. Some Buells too.
That's good to hear. It's a good bit warmer in your part of the world than in mine. I keep running my H.S. and also have had no problems with overheating or anything else, actually. It is a fine little motor and you are right: it does look a whole lot better without the plastic shroud.Hi guys, Long time lurker and rarely post. I have been a huge fan of the the little HS142F Honda clone for a couple of years. Just found this thread and thought I might add something to it. I have been running several HS142's without cooling tin or shroud for over two years without a single problem. Climbing the hills and several thousand miles. Three motors, zero problems. Again, no cooling tin or shroud.
Stationary it might be an issue, but on a bike it doesn't appear to be so. Looks a whole better and gets a whole lot more looks ;-)
