choke on help at all?, partial on, somethings gotta work.......I still wonder if the problem is the carb at all. if you have a bad air leak on a crank seal you'll get simular symptoms. keep looking & keep the faith!
I used ether based starting fluid on my flying horse 80cc to try and get it started... a whole can. the motor still runs great.... it ended up being a bad carb.I read somewhere that Ether starting fluid is real bad for two stroke motors as it purges the lubrication off the piston walls. It said it was okay for 4 strokes - that does make sense to me.
1st time I was in Florida it was cold and I was confused, then the next day the shuttle took off and exploded moments later,... that was horrible,...hope to see the Space Shuttle take off on Feb.24th. that will be soooo cool if I get to see and hear it fly!!!!!
That's what I also did in my bike. +1 for you.Ok this is what happened to me once. My bike was running fine and one day it wouldn't start. I tried to start it again holding down the kill switch and it fired right up. What I did was disconnect the kill switch and run the white wire straight to ground. My friends bike did the same thing...
