David D.
Hi Norm, I am still kinda new to these little engines but this one seems to have a problem....it is a new engine (from flying horse) 66cc and when i took the cover off to grease the gears, the pinion gear was not aligned with the ring gear, was sticking out about an 1/8" so i pushed on it with my thumb and it moved back in place, it's not loose, the whole crankshaft moves...i took the cover off the mag to verifie this.... is this normal? will it cause me any problems down the road? how can i fix it? is there a thrust bearing or shims on the crankshaft? thanking you in advance,David
