Tim_B_172
So I was going to replace my crankshaft and I don't know which one to get.
This one from piston bikes is cheaper, but it doesn't look like my crankshaft. I don't see any holes or screws for the counter weights. I wanted to order it from them because they have a few other things that I need.
This one from Bike Berry looks more like my crankshaft, except for those two holes on either side of the center shaft. I have the counter weights off of the old shaft so bolting them on to the new one is fine with me.
I'm replacing it because I had a serious out-of-balance condition. INSANE vibration at high end and whatnot. I found that the cut-out parts of the counter weights were full of casting sand! And also a portion of the center shaft is not concentric. It's hard to explain, but I'll try. Right where the center shaft is pressed into the crank cheek there is a little groove machined around the shaft. That groove is deeper on one side than the other. If it were just the sand, I would use the old crank but it's not.
Also, it might help to know what the engine is. Redbat 66cc, and according to the sticker it was made in 2010. I don't have the sticker any more so I couldn't narrow down when in '10 it was made.
Sorry for the long-@$$ post, I just wanted anyone who reads to have as much info as possible before answering.
