GearNut
Blue wire is for powering the CDI box alone. If you tap power off of the blue wire you will kill the ignition system. Hook up the full wave bridge rectifier between white and black, which are both sides of the lighting coil on the mag.
Remember, the ignition coil (blue wire) and the lighting coil (white wire) are two separate windings on the mag that share a common ground which is the frame of the mag which the black wire also attaches to.
