Just finished the install on my first bike and went for a short ride. Occasionally will have good power at 3/4 to full throttle, but with the choke off it runs like crap.
The engine also will not idle at all. Unless I'm going pretty fast it just wont stay running. It's dead the second I put the clutch in.
The whole "choke on/runs better" led me to believe its an intake leak. (ie. only runs good with alot of fuel.) I took the manifold off and put Honda-Bond on the intake gasket. When I went to tighten it back down, I noticed the studs were loose. I removed them completely and used bolts instead. i was hoping this would solve my problem, but it seems I have the opposite problem now.
It's constantly four stroking, and if the choke is on it will barely run or move. It will run poorly with occasional normal 2-stroking until the upper rpms with the choke off.
Still no idle...
Still no idle...
