hellhammered
That is sweetness on wheels! How much did the bike weigh before adding the motor?
			The "Hot-Foot Express" is an awesome bike. Who knew putting your head on backwards could have such advantages (though technically it's the whole top end I suppose). You know, if you're handy at fabricating with sheet metal, you could make a little air-cleaner cover with a built-in ram air scoop pointing forward on it.
thanks.
i dunno, 30, maybe 40...tons?
it's pretty heavy duty, but it doesn't weigh that much. probably weighs 50 lbs now. still goes 40-45mph no problem though...
	The reason I ask is because I want to motorize my Flightliner, which is a tank. That's good news, it probably weighs about the same as yours. Cool, Thanks!
i was using a #41 from Fastenal, but it was made in china. it fit better than the stock 415, and looked heavy-duty, but it broke about a month and a half ago so i had a 415 kit chain on again.
the sprocket alignment is dead on, and there's no excessive wear on the sprockets, so all i can think of is the chains are just garbage and can't handle the load i'm putting on them.
Hey Bairdso, when the chain snapped, it took my rear motor mount with it. sheared off both bolts, one of them inside the motor. one came out no prob, the other was pretty well stuck.
so i get out my drill, etc, and found out it cracked the case, and oily grease is coming out from under the clutch.
inspected it some more and found the casting that holds the pin for the clutch actuator is blown up, too.
so, anyone got a Grubee Starfire GT4 case laying around?
