A perfect tune up is possible, with no four stroking anywhere.
Like a real motobike,
Even with the stock HT carb.
You want a lean idle, a slightly richer midrange and a fat full throttle for the hills.
Fuel is the main coolant system on small two strokes.
I have achieved this with 2 mm ground of the bottom of the slide, then adjusting the cutaway to 1.2mm or 1.5mm, ( stock is 1.0) then running a 0.65 or 0.70 main jet.
This setup gives 2 full throttle positions, level with the bore of the carb for the flats (lean) and then 2mm more slide travel gives more fuel for big hills, high loads.
A setup like this setup runs clean on the flats then powers up hills.
No 4 stroking anywhere, and good pickup from low speeds.
Its trial and error but perfect tuneup is posible.
No more 4 Stroking ever.
Tune the needle for a nice mid range.
