Norman
LORD VADER Moderator
some simple things to try disconnect the kill switch and try it. Ohm meters cost about $15.00
at walmart they work good enough for simple wire testing etc.
see if the removing of the kill switch helps also make sure all connections are tight. the magneto coil inside the engine,make sure that the soldered leads are not off on the magneto coil. One wire that comes loose is a bare copper wire, it is hard to see as its soldered right onto the coils frame.
It can come loose or off and is hard to see so look it over good.
