Watts
Was having trouble getting motor going, but determined it was a short in my killswitch connection. The engine works fine and takes me forward as long as I have the killswitch pushed in. I have seen a couple other posts with this same problem.
I just checked the spring under the killswitch and its positioning seems fine and unmoved. The wiring to the killswitch looks fine.
So its not the spring in the killswitch, any other ideas. Could it be a cut or disconnect in my splicing even tho it was taped up with electrical tape.
I checked the spring and wiring to the killswitch and all seems fine and so does the throttle cable. I took it for another ride today and still had to hold the killswitch in to get the motorbike going. I can only seem to hit 28-30km/hr.
I rode about 1km holding the switch in fine only hitting 25-30km/hr and while riding I heard a loud pop twice...sounded like my sparkplug was firing and making noise...spark plug connector was really hot afterwards and also it seems positioned higher than before in the engine.
Any ideas what this popping sounds could be, only happened twice and motor was still running after but I turned off the bike in fear of doing damage. Am I better just removing the killswitch if it can lead to my engine dying ??
Dont know much about gap sizes and what their relation is to spark plugs and performance. Any information on the spark plug gaps etc would be great as well
Thanks
Watts
Thanks
Watts
