im sure there will be some differences in opinion. please let me know if you have had a good experience with a budget kit
Newcomers reading this may be overwelmed.......No matter what kit you get just remember to be prepared to upgrade some parts and modify some of the others, for instants, you will likely need to solder up and then redrill the main jet in the carburetor to a small Dia. hole like maybe a #73 wire gauge , you may need to modify the idler set up so that it will stay put on your bike and not rotate in toward the spokes and cause a huge problem by drilling a hole through the idler and just into the outside part of the bike frame so you can install a self tapping screw to hold it in place once you figure out where it needs to be, you will likely need to replace the engine mounting studs front and back, and the carb. stud and exhaust as well, because the studs that come on these engines are very soft and will cause you trouble down the line most likely, you will need to likely replace the sparkplug boot and and the plug wire while your at it this helps as well, both of my BGF engines run very good but I had to do all of the above mods. in order to get them to the somewhat dependable stage, so just be prepared to make some mods. on any engine kit you deside on. these are all simple inexpensive fixes and upgrades but will make any of the engines work much better in the long run. Good Luck......and becareful.!
In this post I was only being realistic in what I have had to do and what many other on this forum have said they have also had to do in order to get there bike running right and dependable, anyone reading this post has the option of disreguarding anything that does not apply, but at the same time all the things I listed with maybe the exception of having to drill the jet will make there engine more dependable and they need to know that probably 90% of the time there will need to be some mods. made in order to get there bike working the way it should, I figure if these kits were just a very simple bolt on and go, we would not have 1000's of post on this forum asking for fixes and people who have "been there done that" providing how to info. for fixing all the many issues most encounter with most all of these kits.Newcomers reading this may be overwelmed.......
Although these mods may help... they are not necessarily a must. You can by an engine kit , install it properly and have a good riding bike.
Sure, there are preventative steps in the build that will help with ease of installation. Read up and ask questions.
Amen...................!My first build I did kind of blind. I didn't know about this forum and spent a lot of time fiddling with this and that trying to get the chain aligned, etc. Once I got her going it was a 12 year old's dream come true and something I wanted fifty years ago. You can do OK with what comes stock in a kit and have a blast. Probably some problems will come up now and then and you'll become more knowledgeable as you go. Down the line you'll no doubt become something of an expert and will have made some of the improvements mentioned in this thread. But when all is said and done, it's a bicycle with a simple little motor on it without a whole lot of money involved (unless you get in deep). Sure, try to do a good job with your initial install, for sure wear a helmet and don't try to go too fast at first. Mainly though, have some fun! Get 'er going and ride! If you want to get all serious about it later that's fine, too. Life is too short to get your pants in a bundle about every little thing.
SB
